external captive portal - radius authentication vs authentication text
  • 1.  external captive portal - radius authentication vs authentication text
    Posted May 30, 2014 10:50 AM
    i can't find a clear explanation in the documentation and the different threads on airheads also miss some details i need.
    so what is the exact difference? is it like?
    send user to external page where he / she enters credentials which are then HTTP POSTed back to IAP which sends them to configured authentication server?
    - authentication text
    send to user external page where he / she enters credentials which are checked by local page which then shows a page with a string on which the signals the authentication succeeded or not?
  • 2.  RE: external captive portal - radius authentication vs authentication text
    Posted Jun 02, 2014 08:24 AM
    From my tests the conclusion is as follows:
    - authentication text method is as follows :
         - User gets redirected to external page
         - External page sends back to the iAP only a POST entry with text : "authenticated"
    - radius authentication as follows:
        - external page returns the username and password and other hidden attributes to the iAP
        - iAP checks the information against the RADIUS server configured
        - based on the check the client would get in post auth role
        - if you are using the "role based auth" then based on the answer back from your RADIUS you could have triggers to select other post auth roles.
  • 3.  RE: external captive portal - radius authentication vs authentication text
    Posted Jun 02, 2014 01:57 PM
    thank you, makes sense. would be nice if Aruba put that in a manual or such.
  • 4.  RE: external captive portal - radius authentication vs authentication text
    Posted May 18, 2015 07:32 AM
    Dear ,
    I canot understand about this sentence:
    It's like that?
              <form method="post" action="/cgi-bin/login">
                    <input type="hidden" name="authenticated" value="authenticated" />
                    <input type="hidden" name="cmd" value="0" />
                    <input type="submit" name="Login" value="I Agree" class="button" />
            </form>
    But The Server   Return that Error Message :
    <html><pre>Error in invocation. Error string - bad ret code</pre></html>
    (So I donot how to  POST entry with text : "authenticated")
    Thaks!
  • 5.  RE: external captive portal - radius authentication vs authentication text
    Posted Jun 18, 2015 03:56 PM
    Evan Lin,
    I have the same problem.
    I cannot figure out how to send back this "Authenticated" text to the IAP.
    Did you find a solution ?
  • 6.  RE: external captive portal - radius authentication vs authentication text
    Posted Jun 19, 2015 04:19 AM
    Not Yet !!
    But You can Try like this,before you set the right user/password in the iap
    Jquery Code :
    $("#password").val('123456');
    $("#user").val('test');
    $("#wifi_form").attr("action", http://192.168.100.25/cgi-bin/login);
    $("#wifi_form").submit();
