External captive redirects to internal captive portal
  • 1.  External captive redirects to internal captive portal
    Posted Nov 24, 2022 12:08 PM
    Hello, i'm using an external captive portal for 3 aruba 515, i'm using Purple WiFi, I configured the SSID and everything works well on Desktop, but on mobile devices once you loggin on the splash page instead of redirect to google.com and connect to the internet, it redirects me to the following page.
  • 2.  RE: External captive redirects to internal captive portal
    Posted Nov 24, 2022 07:21 PM
    check your splash page type to be external and set the captive portal profile. like it is shown below.
  • 3.  RE: External captive redirects to internal captive portal
    Posted Nov 25, 2022 05:30 AM
    Can you check/find out what is the URL for that page that you are redirected to?
