External dns
  • 1.  External dns
    Posted Sep 05, 2012 05:36 AM
    Aruba design guide recommends  to use external DNS when possible for captiveportal based  guest access.
    If external DNS  is in play, does the controller  management IP participate in any  DNS (send/receive) at all during guest  redirection/handover process? ( Note.we are sourcing packets from mangment not loopback)
    Put it differently, does the controller require DNS  connectivity in guest implmentation?
    With  Trapeze implmentations,I had to allow DNS to be sourced from the controller but  thought of getting  some  thoughts from the forum.If there is a document/link to this info that would be great.
    nerd
  • 2.  RE: External dns
    Posted Sep 05, 2012 06:06 AM
    The client needs to be able to resolve DNS.  Absolutely.
    Please see the "Guest Access with ArubaOS" design guide on this page for guest access details:  http://www.arubanetworks.com/technology/reference-design-guides/
  • 3.  RE: External dns
    Posted Sep 05, 2012 07:47 AM
    Thanks Joseph.
    I have no doubts on the clients and DNS connectivity. The question was about the controller  and DNS.
  • 4.  RE: External dns
    Posted Sep 05, 2012 12:30 PM
    The guest role should have "permit" for DNS traffic on the controller i.e. the controller will just pass through the DNS requests from the client.
  • 5.  RE: External dns
    Posted Sep 05, 2012 03:20 PM
    guest role is allowing DNS  traffic.
    let me explain with an example..
    suppose we throw a firewall between the controller and internet, controller IP is 192.168.10.50/29 and the guest client subnet is 172.16.20.0/24.
    I have allowed  DNS/http/https  on the firewall for 172.16.10.0/24 only.do i need to punch a hole for  192.168.10.50/29 ?
  • 6.  RE: External dns
    Posted Sep 05, 2012 03:49 PM
    I don't know if you made a mistake, but you need to allow DNS from the guest subnet of 172.16.20.0/24 for this to work.
  • 7.  RE: External dns
    Posted Sep 05, 2012 04:37 PM
    Thanks Joseph.
    This is what we have configured:
    netdestination P-DNS
      host a.b.c.d
      host  e.f.g.h
    ip access-list session guest-logon-access
      user any udp 68  deny
      any any svc-dhcp  permit time-range w-hours
      user   alias P-DNS svc-dns  permit time-range w-hours
  • 8.  RE: External dns
    Posted Sep 05, 2012 05:12 PM
    one more thing folks.
     there is  dst-nat 8081 on the  controller ACL .So I think  I need to open port 8081 on the upstream firewall as well.
  • 9.  RE: External dns
    Posted Sep 05, 2012 07:50 PM
    No, you don't.
    The only thing you need is for the clients (not the controller) to be able to resolve DNS.  The controller's role is only to pass the client's traffic.  It does not directly resolve DNS and does not source DNS packets.
  • 10.  RE: External dns
    Posted Sep 05, 2012 08:05 PM
    Thanks  for the reply Joseph,
    Looking at the steps involved in guest authentication, it seems that it breaks from Step 14 onwards.
    Investigations continues...
  • 11.  RE: External dns
    Posted Sep 05, 2012 08:08 PM
    Do you have a "welcome page" configured in your Captive Portal authenticaton profile?
    After step 14, can the client then open a different browser and do anything?
  • 12.  RE: External dns
    Posted Sep 05, 2012 08:35 PM
    No we don't have a welcome page.
    Please below for the captiveportal related configuration.
    ip access-list session captiveportal
     user   alias controller svc-https  dst-nat 8081
      user any svc-http  dst-nat 8080
      user any svc-https  dst-nat 8081
    user-role guest-logon
    captive-portal "guestnetwork"
    access-list session logon-control
    aaa authentication captive-portal "guestnetwork"
       default-role "auth-guest"
       server-group "Internal"
       protocol-http
       white-list "ocsp.usertrust.com"
    user-role auth-guest
    access-list session cplogout
    access-list session block-internal-access
    access-list session auth-guest-access
    access-list session drop-and-log
    Strange thing is that once authenticated, DNS breaks on the client device.
    Have not tried a different broweser but will do so shortly.
  • 13.  RE: External dns
    Posted Sep 05, 2012 08:41 PM
    You should consider creating your guest network from the WLAN/LAN wizard and take it from there.  That is the simplest way to make it work.
  • 14.  RE: External dns
    Posted Sep 05, 2012 08:51 PM
    I did not use a wizard but will keep it as my last resort.
  • 15.  RE: External dns
    Posted Sep 05, 2012 09:46 PM
    Interesting observation, prior to authentication I can see DNS query/reply but post authentication in only see queries no reply from DNS server.
    I'm going to run some debugs on the controller.
  • 16.  RE: External dns
    Posted Sep 11, 2012 07:41 PM
    Hi ,
    Have been away last few days. The cause of the DNS malfunction was due to the fact that NTP was off and this resulted the time based ACLs to play havoc.
