External - RADIUS authentication
  • 1.  External - RADIUS authentication
    Posted May 14, 2014 07:34 AM
    I've been configuring up some Instants on code version 6.3.1.2-4.0.0.4_42384 and have noticed that the option, on a guest WLAN for external authentication using RADIUS as the splash page type is not available in the drop-down. Whats happened? I'm sure this option was there before.
  • 2.  RE: External - RADIUS authentication
    Posted May 14, 2014 08:58 AM
    Screenshot?
  • 3.  RE: External - RADIUS authentication
    Posted May 14, 2014 09:03 AM
    I've poked around a bit further and it looks like this is now setup under Security>External Captive portal. Then added into the WLAN. In the Captive portal configuration do i need to use port 443?.
  • 4.  RE: External - RADIUS authentication
    Posted May 14, 2014 02:18 PM
    No - you don't need to use 443.
  • 5.  RE: External - RADIUS authentication
    Posted May 16, 2014 03:14 AM
    I cant complete the settings page without entering a port number.
  • 6.  RE: External - RADIUS authentication
    Posted May 28, 2014 09:04 AM
    What port number needs to be used on the External captive portal setup page?
  • 7.  RE: External - RADIUS authentication
    Posted May 28, 2014 09:06 AM
    Depends on the page. Usually 443 or 80
  • 8.  RE: External - RADIUS authentication
    Posted Jun 05, 2014 04:47 AM
    Looks to be working with 443.
