External SSL Captive portal
  • 1.  External SSL Captive portal
    Posted Jul 12, 2017 08:21 AM
    Hi guys!
    I need to use an external captive portal with my Instant cluster, but this captive portal is configured to accept SSL HTTPS connections only.
    In the instant GUI there is no "use https" option as in the controllers, how can I do the trick?
    Thanx a lot in advance!
  • 2.  RE: External SSL Captive portal
    Posted Jul 12, 2017 08:28 AM
  • 3.  RE: External SSL Captive portal
    Posted Jul 12, 2017 08:35 AM
    I'm sorry, I missed a detail: I'm using authentication text as Captive portal Type...
  • 4.  RE: External SSL Captive portal
    Posted Jul 12, 2017 08:44 AM
    This should do the trick:
  • 5.  RE: External SSL Captive portal
    Posted Jul 12, 2017 08:47 AM
    Unfortunately, no.
    The remote server says that I'm trying to access an HTTPS page without using SSL.
    I think that using authentication text is not possibile to do the trick...
