Extra Parameter for External Portal OR 301 Redirect with extra data
  • 1.  Extra Parameter for External Portal OR 301 Redirect with extra data
    Posted May 07, 2018 05:09 AM
    Hi All,
    I am looking to add an extra parameter to the parameters provided when redirecting to an external URL for authentication.
    The parameter  will be hosted on a local server and can be fetched however deemed fit, I was thinking of a simple HTTP request to for example "192.168.3.123:3322" could return a value that could then be added to the request.
    Alternatively I was thinking of using a local web server to 301 redirect to another server address that would repeat the parameters but add the extra parameters the external portal requires.
    Has anybody done something similar or have any tips?
    I have attached a rough drawing of what I was thinking of building
    Thankyou
    Details of the other parameters:
    http://www.arubanetworks.com/techdocs/Instant_421_WebHelp/Content/UG_files/CaptivePortal/External%20Captive%20Portal.htm
