Extract RF Plan from switch following "upgrade" to 6.3
  • 1.  Extract RF Plan from switch following "upgrade" to 6.3
    Posted Jun 09, 2014 09:28 AM
    As above really, seems a real step back to loose the RF plan feature. Now when a client phones up about poor reception we can't tell which access is nearest to that room.
    I do have flash backups pre upgrade, can they be extracted them these? Thanks.
  • 2.  RE: Extract RF Plan from switch following "upgrade" to 6.3
    Posted Jun 09, 2014 09:31 AM
    Only if you restore it to a controller, pre-6.3 can you get the RF plan off, unfortunately.
  • 3.  RE: Extract RF Plan from switch following "upgrade" to 6.3
    Posted Jun 09, 2014 09:32 AM
     ok, that's progress (
