Network Management
Extremely basic template for auditing
  • 1.  Extremely basic template for auditing
    Posted Jul 18, 2017 02:41 PM
    I'd like to create a template that looks for a single AAA profile with static information.  Something like:
    ----begin template
    aaa profile "wifi-aaa_prof"
    authentication-dot1x "dot1x_prof-bna32"
    dot1x-default-role "authenticated"
    dot1x-server-group "wifi_srvgrp-slc59"
    ----end template
    All I want Airwave to audit against is the above section, and all other configuration line items can be ignored.  After creating the template above and applying to a group, then auditing the current versus desired config, I get a mismatch which is shown as below:
    Actual   aaa authentication captive-portal "Blah-cp_prof"
    Desired
    Actual   aaa authenticaiton captive-portal "Guest-cp_prof"
    This is the only entry of "Desired" but there's nothing there.  I then modified the template to ONLY have
    ----begin template
    hostname %hostname%
    ----end template
    Which seems like all I should be looking for is whether it has a hostname, right? Well, the same result occurs.  Has anyone else tried to do something like this, where you prune out a majority of a config and only look for one specific section?
    Am I doing this completely wrong, or is this some sort of bug?
