Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Extremely low speed under WPA3 CNSA 192bit mode
  • 1.  Extremely low speed under WPA3 CNSA 192bit mode
    Posted 17 days ago
    We've been trying to deploy the WPA3-CNSA(192-bit), and we have already been using EAP-TLS for a long time. Before Instant 8.11, No client could connect to CNSA mode SSID. After 8.11, they can connect, but the speed will be extremely slow( maximum 10-30Mbps). Initially, we thought it was a performance issue on 505 until we got our first 655 yesterday.
    It's a monster. We can get a stable 800 Mbps on the ax 5Ghz 80Mhz channel. However, speed drops happened again when CNSA is on. We've tried to disable k/v/r roaming and all the IDS&IPS. Nothing changed. We even tried to create a new CA and Client Cert with different parameters( RSA vs Curve & key length). It is just a bit weird. Any ideas will be appreciated. Thanks
    BTW, we can't find the factory firmware(Without login) for the whole 6xx series AP
  • 2.  RE: Extremely low speed under WPA3 CNSA 192bit mode
    Posted 16 days ago
    when you enable CNSA mode, does the CPU spike?
  • 3.  RE: Extremely low speed under WPA3 CNSA 192bit mode
    Posted 16 days ago
    No, it's even 10% lower when running Speedtest  compared to  WPA3-128(30% in CNSA, 45% in 128 for AP505) . RAM usage is also normal. Thanks
  • 4.  RE: Extremely low speed under WPA3 CNSA 192bit mode
    Posted 16 days ago
    what supplicant do you have for WPA3-CNSA(192-bit)?
  • 5.  RE: Extremely low speed under WPA3 CNSA 192bit mode
    Posted 16 days ago
    Mainly Apple Devices. M1 iPad Pro/MacBook and some iPhone(Minimum 12)
    Minimum OS version: iOS 15.6 and MacOS Monterey. Thanks
  • 6.  RE: Extremely low speed under WPA3 CNSA 192bit mode
    Posted 15 days ago
    please reach out to our TAC and let them investigate further.
    Any opinions expressed here are solely my own and not necessarily that of HPE or Aruba.If my post was useful accept solution and/or give kudos.
  • 7.  RE: Extremely low speed under WPA3 CNSA 192bit mode
    Posted 9 days ago
    The firmware for the AP-6xx is on the AP already, and you can use the in-product update to get to the latest recommended version. That is probably why there is no factory image available (yet).
    For the slow performance, that can also be a client/driver issues, or an issue that the encryption for CNSA 192bit is not supported in the hardware of your clients and performed in sotfware with a lower performance. This definetely needs to be further investigated, so I would +1 the recommendation to get TAC involved.
