FACEBOOK - Your connection is not private
  • 1.  FACEBOOK - Your connection is not private
    Posted Nov 05, 2015 08:36 AM
    Hi Guys,
    We have problem when we are redirecting to facebook login.
    We already whiteslisted the facebook domain inside the role.
    See the images below.
    Bien
  • 2.  RE: FACEBOOK - Your connection is not private
    Posted Dec 20, 2015 07:48 AM
    from where are you redirecting? after succesful captive portal login or before? which certificate is presented to the client?
  • 3.  RE: FACEBOOK - Your connection is not private
    Posted Feb 12, 2016 05:02 AM
    Same issue here. We are using Clearpass with instants. I'm trying to setup Facebook authentication. During the authentication attempt im getting the same error message and the certificate is an instant certificate instead of cppm's server certificate. Any idea would be appreciated.
  • 4.  RE: FACEBOOK - Your connection is not private
    Posted Feb 13, 2016 06:22 AM
    this can't be prevented. you are trying to interupt a https request and that will cause a message like this, using a certificate from a trusted CA helps a little but in the end you will always receive messages (and you should else it wouldn't be save) if you interupt a https session.
