factory Reset
This thread has been viewed 22 times
  • 1.  factory Reset
    Posted Nov 05, 2014 09:41 AM
    how to do factory reset in aruba 3600 controller?
    #3600
  • 2.  RE: factory Reset
    Posted Nov 05, 2014 09:42 AM
    Make sure you take note of your license keys.
    write erase all
  • 3.  RE: factory Reset
    Posted Nov 05, 2014 09:54 AM
    from serial console or lan ?
  • 4.  RE: factory Reset
    Posted Nov 05, 2014 09:55 AM
    You can either console in or SSH over the network.
  • 5.  RE: factory Reset
    On the CLI use the command "write erase all".
    Be sure to save your licenses before executing this command as it will delete licenses as well.
