Factory Reset
This thread has been viewed 33 times
  • 1.  Factory Reset
    Posted Feb 13, 2019 10:55 AM
    Hi aruba apın205 device I am trying to change the factory settings. I press the reset button when the device is off ethernet cable I wait 5 seconds and I pull my hand from the reset button. .What should I do? Can I connect to a modem and access the IP interface from the internet interface?
  • 2.  RE: Factory Reset
    MVP EXPERT
    Posted Feb 13, 2019 11:04 AM
    Hi Erhan28
    You have to hold the reset button for 15sec while power on the AP
    1. remove power
    2. hold the reset button
    3. power on the AP while hold the reset button
    4. release the power button after the first 15 seconds of the boot proces
