Factory Reset AP225 w/o having to pull them down
  • 1.  Factory Reset AP225 w/o having to pull them down
    Posted Jan 12, 2017 01:53 PM
    Hi All, I have around 200 AP225s in different locations that are currently controller based.  I'd like to know if I can ssh into the APs or somehow reset them back to factory defaults from the controller?  I'd like to build them out into Instant clusters - but I really don't want to visit each room and pull them down to reset them if at all possible.
    Thanks for any input!
  • 2.  RE: Factory Reset AP225 w/o having to pull them down
    Posted Jan 12, 2017 02:03 PM
    Unfortunately, the only way is to hit that reset button.  Did they all start out as instant APs?
  • 3.  RE: Factory Reset AP225 w/o having to pull them down
    Posted Jan 17, 2017 10:32 AM
    That's what I figured - guess we will need ladders :).  Yes, these were all instants that we converted, our original roll out and larger sites have controllers.
