last person joined: 2 hours ago
Factory resetting an Instant AP 270, any suggestions?
  • 1.  Factory resetting an Instant AP 270, any suggestions?
    Posted Mar 09, 2015 02:58 PM
    Unsuccessful in resetting an Instant AP 270, any suggestions?
    I have held the reset button down while powering on the device for 10 seconds with no success.
    Brandon
  • 2.  RE: Factory resetting an Instant AP 270, any suggestions?
    Posted Mar 09, 2015 03:40 PM
    Did you try the specific instructions here:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=1634
    "Reset Button The reset button can be used to return the AP to factory default settings. To reset the AP: 1. Power off the AP. 2. Press and hold the reset button using a small, narrow object, such as a paperclip. 3. Power-on the AP without releasing the reset button. The system LED will flash within 5 seconds. 4. Release the reset button. The system LED will flash again within 15 seconds indicating that the reset is completed. The AP will now continue to boot with the factory default settings."
    If that does not work, and you don't have a console cable, please contact TAC.
  • 3.  RE: Factory resetting an Instant AP 270, any suggestions?
    Posted Mar 09, 2015 03:44 PM
    I was able to get it reset.  We can close this out.
  • 4.  RE: Factory resetting an Instant AP 270, any suggestions?
    Posted Mar 10, 2015 12:12 PM
    What did you end up doing to get it reset?
