Failed MAC AUTH
  • 1.  Failed MAC AUTH
    Posted Feb 12, 2019 12:46 PM
    I finally think I have beat the Appl CNA issue I have been having. Now I want to fix my metrics as MAC AUTH is throwing a ton of Failed Authentications and I dont really want to see a Failure on a device that has NEVER been connected before. Now if I get a MAC AUTH failure on a known endpoint, that would be good to have in the log.
    Maybe I can AUTH the unknowns and put them in the login role. But a pass most likely wouldn't jump to the User Auth with Mac Cacheing right?
  • 2.  RE: Failed MAC AUTH
    Posted Feb 12, 2019 12:49 PM
    Allow All MAC Auth should always be used with any MAC auth workflow to drop the device into either a profile or splash role.
  • 3.  RE: Failed MAC AUTH
    Posted Feb 12, 2019 12:54 PM
    So i have Allow All MAC AUTH as the Authentication Method. Are you saying instead of "Deny Access Profile" on the Default Profile for the Enforcement Policy, I should pick the guest-login role?
  • 4.  RE: Failed MAC AUTH
    Posted Feb 12, 2019 12:56 PM
    Yes, create a new enforcement profile that returns your splash or profile role.
  • 5.  RE: Failed MAC AUTH
    Posted Feb 12, 2019 02:42 PM
    Thank you, this Apple CNA has been stressing me and I finally seem to have it working. 300 person event tomorrow will be the true test. Wish I could remove all those thousands of failed auths to help the metrics, but I may let time average it out and use it for future reference.
