What is described in the post is probably not a problem, but expected behavior.
Please open a new thread with all the information, like your policy setup, messages in access tracker, etc. Or may be better to open a TAC case as much more information needs to be checked to first understand your problem first, then your configuration and come up with the proper configuration.
Original Message:
Sent: Dec 07, 2023 11:25 AM
Subject: Failed to construct filter
Hello!
I have exactly the same problem for all Apple iDevices. Did you found a solution?
Thank you
Original Message:
Sent: Feb 10, 2017 02:17 PM
When im doing the seft registration sometimes i get the captive portal again and i have to register twice. After the second time it works...
When i get the captive portal again i get this error on the access tracker
![error.PNG error.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/21e221edc9524b17a7a1f58270a3f7d6_47e9c6e9fe7848768a4d8e846510b46c)
Here is the config of the service
![authenti source.PNG authenti source.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/21e221edc9524b17a7a1f58270a3f7d6_ce1abcbaf91e4cb68bda53dd3e8a8afd)
![auth source.PNG auth source.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/21e221edc9524b17a7a1f58270a3f7d6_2ce25d3ff5ff4e3c87529352c9c93983)
![role.PNG role.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/21e221edc9524b17a7a1f58270a3f7d6_1330b2252592453285f2d414503a3b93)
![enforment.PNG enforment.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/21e221edc9524b17a7a1f58270a3f7d6_bb92042cf1a04091b7b4b1f04513f69e)
