Failed to decrypt key.
  • 1.  Failed to decrypt key.
    Posted Sep 25, 2013 03:02 PM
    I am having trouble installing an ap license on a 620. The license is for the correct serial number controller. Two of the three generated licenses installed no problem. Am I simply overlooking something simple?
  • 2.  RE: Failed to decrypt key.
    Posted Sep 25, 2013 03:26 PM
    Does that key belongs to another controller by any chance ?
  • 3.  RE: Failed to decrypt key.
    Posted Sep 25, 2013 03:46 PM
    ... most common issue I have seen... whitespace at end of the key string.
    Sometimes the answer is in plain view with a whitespace at the end of the string, which will give you that error.
    Something to check.
    JF
  • 4.  RE: Failed to decrypt key.
    Posted Sep 25, 2013 04:35 PM
    The AP license was generated with this controllers cert and serial so I don't think it is shared but ill dig deeper on that.
    I checked and triple checked the string its identical. So I'm still kinda scratching my head as to what the problem is.
    Thanks for the replies.
