"Failed to generate certificate" error message
  • 1.  "Failed to generate certificate" error message
    Posted Mar 07, 2012 08:18 AM
    Hello all,
    After upgrading from 5.0.3.1 to 6.1.3.0, I get the following messages on all of my controllers, constantly:
    Mar 7 08:06:59 cpsec[1884]: <335102> <ERRS> |cpsec| handle_gen_cert, Failed to generate certificate, return code -1.
    Mar 7 08:08:27 cpsec[1884]: <335102> <ERRS> |cpsec| handle_gen_cert, Failed to generate certificate, return code -1.
    Any ideas what might cause this?
    Dave
  • 2.  RE: "Failed to generate certificate" error message
    Posted Mar 07, 2012 09:33 AM
    Do you have control-plane-security enabled on the controllers? What do you see under "show tpm cert-info" and "show tpm errorlog"?
  • 3.  RE: "Failed to generate certificate" error message
    Posted Mar 08, 2012 10:45 AM
    show control-plane-security is as follows:
    Control Plane Security - Disabled
    Auto Cert Provisioning - Disabled
    Auto Cert Allow All - Enabled
    Auto Cert Allowed Addresses - N/A
    The output of the other commands:
    show tmp cert-info
    subject=/C=US/ST=California/L=Sunnyvale/O=Aruba Networks/OU=Engineering/CN=00:0b:86:61:00:75
    - I've left out the next few lines because they contain an email address and a serial number
    - the Dates listed are within an appropriate range.
    show tpm errorlog
    - no error logs
    Dave
  • 4.  RE: "Failed to generate certificate" error message
    Posted Mar 09, 2012 10:12 AM
    Hello Dave,
    I would suggest opening a ticket with our TAC team so that they can have the logs analyzed and open a ticket with Engineering if
    needed to analyze the error message and find the trigger for it being generated.
    -Bharatharajan Pudugraam
