Failed to login to IAP VC
  • 1.  Failed to login to IAP VC
    Posted Sep 12, 2016 10:22 AM
    Since ARUBA-SA-20160908-01, I can not even login to the Web UI of IAP VC (Running version 6.4.2.3-4.1.2.1) to apply a new certificate.
    Both IE 11 and Chrome prompted me saying the certificate is revoked...
    Should I keep tried different browsers OR you guys have better options for me?
    /S
  • 2.  RE: Failed to login to IAP VC
    Posted Sep 13, 2016 08:03 AM
    Am I the only one...help!!!
  • 3.  RE: Failed to login to IAP VC
    Posted Sep 13, 2016 09:35 AM
    You'll have to connect to the CLI to change the certificate. Either that, or different browsers/clients
    might be a useful link (considering the age of the document):
    http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/Authentication/Certificates.htm
  • 4.  RE: Failed to login to IAP VC
    Posted Sep 13, 2016 09:45 AM
    Thanks, will give it a try...
  • 5.  RE: Failed to login to IAP VC
    Posted Sep 13, 2016 09:40 AM
    You can temporarily disable OCSP/CRL checks in your browser as a workaround.
    Be sure to re-enable when you're done.
  • 6.  RE: Failed to login to IAP VC
    I could try to see if I could modify the GP on my local account...not going to happen to modify the domain GP, even temp...
