Failed to migrate from 6.5 to 8.5
  • 1.  Failed to migrate from 6.5 to 8.5
    Posted Mar 03, 2020 11:52 AM
    I try to migrate from 6.5 to 8.5 MCM ; standlone mode.
    I have this error message :
    flash/config/partial/
    flash/config/setup/
    flash/config/setup/.roleinfo
    [2020-03-03 12:24:23,975: WARNING/Worker-1] Running command: 'copy scp: y.y.y.y root /root/Migration/GUI/.importedConfig/x.x.x.x/standalone/flashbackup.tar.gz flash: flashbackup.tar.gz' on x.x.x.x
    [2020-03-03 12:24:28,767: WARNING/Worker-1] Error: File Copy Failed!! Stopping the migration. Please check the logs for more details
    [2020-03-03 12:24:28,771: WARNING/Worker-1] --------------------
  • 2.  RE: Failed to migrate from 6.5 to 8.5
    MVP EXPERT
    Posted Mar 04, 2020 03:30 AM
    Couple of questions, what type of controller is this? Are you using the migration tool for this?
    The error states SCP has failed, is SCP permitted between the controller and migration tool.
  • 3.  RE: Failed to migrate from 6.5 to 8.5
    Posted Mar 04, 2020 03:39 AM
    Aruba 7205.
    SCP is permitted between the controller and migration tool.
    As you can see in the log before :
    [2020-03-03 12:24:08,396: WARNING/Worker-1] Running command: 'copy scp: y.y.y.y root /root/Migration/GUI/.importedConfig/x.x.x.x/db/dbmigration/data/migrate flash: migrate' on x.x.x.x
    [2020-03-03 12:24:13,060: WARNING/Worker-1] Completed 'copy scp: y.y.y.y root /root/Migration/GUI/.importedConfig/x.x.x.x/db/dbmigration/data/migrate flash: migrate'
    [2020-03-03 12:24:23,108: WARNING/Worker-1] Detected
    [2020-03-03 12:24:23,108: WARNING/Worker-1] version 6.5
    [2020-03-03 12:24:23,109: WARNING/Worker-1] Running upgrade filters.
    [2020-03-03 12:24:23,964: WARNING/Worker-1] Running upgrade filters finished
    flash/
    flash/config/
    flash/config/full/
    flash/config/full/3node
    flash/config/full/.fresh_boot
    flash/config/full/.standalone
    flash/config/full/.migration
  • 4.  RE: Failed to migrate from 6.5 to 8.5
    Posted Mar 04, 2020 09:27 AM
    I've tried a ove version MigrationTool_V3.2.3 with version Aruba Mobility Controllers (AOS) v8.3 but always the same  Error: File Copy Failed!! Stopping the migration. Please check the logs for more details.
    connection is good between controller and the tool, SCP not blocked..
  • 5.  RE: Failed to migrate from 6.5 to 8.5
    Posted Mar 06, 2020 03:48 AM
    After analysis :
    1.)My virtual machine was hosted in my laptop,so the flashbackup generation was not fast due to a performance problem, so when the controller tries to recover a file which is not yet generated the update fails.
    2.) When a I tried to update the controller from 6.5 to 8.5.0.4 in ftp i got this error message : Error upgrading image: ncftpget ArubaOS_72xx_8.5.0.4_72900: could not retrieve remote file.
    But l'upgrade is successful with ftp in 8.3 or 8.2.
    3.) the solution was to upgrade in TFTP (8803 second) directly to 8.5.0.4.
    Is this a bug in 8.5.0.4 ?
    Regards Brahim
