last person joined: 11 hours ago
Failed to upgrade to ClearPass 6.7
  • 1.  Failed to upgrade to ClearPass 6.7
    Posted Dec 16, 2017 06:58 AM
    Hello community,
    When trying to upgrade to ClearPass 6.7 (from ClearPass 6.6.8), I ran into the following error:
    The error message said that backup config had failed, but I didn't know why. FYI, I've already installed all available patches before upgrading:
    I tried to upgrade twice and still the same error. How should I proceed from this?
    Thank you,
  • 2.  RE: Failed to upgrade to ClearPass 6.7
    Posted Dec 16, 2017 07:20 AM
    Please work with TAC for issues like this.
  • 3.  RE: Failed to upgrade to ClearPass 6.7
    Posted Jan 11, 2018 09:57 AM
    This issue has been solved. Turned out that I was running low on disk space and after extending it, I can upgrade to 6.7 without any problems.
  • 4.  RE: Failed to upgrade to ClearPass 6.7
    Posted Jan 14, 2018 05:15 PM
    Thanks for reporting the solution for future readers!
  • 5.  RE: Failed to upgrade to ClearPass 6.7
    Posted Jan 16, 2018 02:46 AM
    How did you extend the disk size ?
  • 6.  RE: Failed to upgrade to ClearPass 6.7
    Posted Jan 16, 2018 03:38 AM
    Hi Fabien,
    This was my lab CPPM (I wanted to test upgrade in lab first before doing it in production environment) so I was free to take it down and extend the disk. I didn't know the detail steps since the VMware ESXI is under control of a different team. But I can ask them what they did if you need the info :)
    Thank you,
