Hello, I'm new here. My name is Hubert. I have 2 Clear Pass VMs. one as a Subscriber and a publisher.I want to import the latest patch 2 for 6.6.0. However, I get the following error: ". Download is stuck or interrupted Run Check Status Now and retry." If I want to import the patch manually then the following error message appears: "Please Error in processing request retry ...."I'm stuck here. What can I do?Greeting Hubert
On the download stuck sometimes if you hit save again on the sub ID It will clear the error, or TAC can clear the error.
On you upload issues I seen issues with some browsers. Can you try a different browser?
Hi Tarnlod,
Hi, I have the sub id removed and stored. Subsequently, the sub id added again. It's still the same message. What is a TAC? A support call? We have support from Dell? Where can I create a TAC?
Hello, I was able to solve Probelm where I update to the CLI using the command "system update -i http: //meinwebserver/CPPM-x86_64-20160819-clearpass-6.6-updates-2-dell-66-patch.signed tar "have installed.Thank you very much
I got similar issues when update from 6.7.7 to 6.7.8, but the real reason was that my diskspace was running out in my HomeLAB enviroment (didnt mention that from the webgui). This article point me in the right way, thanks!
For a easy webserver without need to install it, i would recommend "usbwebserver" http://www.usbwebserver.net/webserver/
