Hi pals,
Is Fallback mode (backup configuration) still available in ArubaOS 8.4.0.0?. In the manual there used to be a section that explained how it this feature works, but it seems it has been deleted.
Reference:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33771
Chapter 33: Remote Access Points
Thanks in advance for your help.
Regards
https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/content/arubaframestyles/remote_ap/config_fallback_mode.htm
Hi cjoseph,
Your link explains how to configure Fallback mode, but ... what is fallback mode?, how does it work?, what are the considerations I should take? ... I cannot find any reference about it in the manual you posted.
Please see here: https://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Remote_AP/Advanced_Configuration_O1.htm#remote_ap_1516596501_1062833
