Hi, AFAIK, only HPE 1920 OfficeConnect Switch Series models non-48 ports and non-PoE/PoE+ are fanless...said so...48 ports model is noisy (I know)...since all models haven't a dedicated Temperature Sensor I think Fan is managed internally - probably (at best) - looking at some related CPU load threshold(s).
I don't know if you can safely disconnect the internal factory installed fan [*]...without incurring, at best, in logged Warnings/Alerts/Errors...at worst, in a non working unit. Never tried, I don't encourage you to do that tweak...48 ports unit and PoE/PoE+ are designed in that way probably because HPE, correctly, thought that they should be installed inside a Rack.
[*] ...or replace with a less noisy fan, see something like doing hacking/tweaking replacing the factory fan with a more silent fan...see here an example on similar 1910 Switch Series <-- clearly...say bye bye to Warranty once you open the unit to do the material tweak.
