FAP and HAP
  • 1.  FAP and HAP
    Posted Sep 10, 2014 12:09 PM
    Hello All,
    Just want to find out can multiple FAP setup a GRE tunnel to the same HAP without load balancing enabled?
  • 2.  RE: FAP and HAP
    Posted Sep 10, 2014 12:10 PM
    What is FAP and HAP?
  • 3.  RE: FAP and HAP
    Posted Sep 10, 2014 12:13 PM
    Home AP = AP to client is connect in the original cluster = HAP
    foreign AP = AP in another cluster = FAP
  • 4.  RE: FAP and HAP
    Posted Sep 10, 2014 12:34 PM
  • 5.  RE: FAP and HAP
    Posted Sep 12, 2014 12:05 AM
    Thanks Marcus. So with that disabled, each more than 1 FAP will establish a GRE tunnel each to the HAP?
  • 6.  RE: FAP and HAP
    Posted Sep 12, 2014 11:00 AM
    Take a look at our online training videos here:http://cloud.arubanetworks.com/instant-training .
    Scroll down and find module 13 "Roaming".  This is a short but informative video (13 min) but you can skip forward to about 8:30 for a discussion on Load Balancing and client behavior.
  • 7.  RE: FAP and HAP
    Posted Sep 14, 2014 10:08 AM
    Thanks Marcus. Had gone through it befor ejust to make usre I get the correct infromation.
