feature is not enabled in the license - captive portal
This thread has been viewed 21 times
  • 1.  feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 06:12 AM
    Hi ,
    Infact I’m having an issue when configuring Captive Portal.
    I followed below link to know how to configure it.
    https://www.arubanetworks.com/techdocs/ArubaOS_80_Web_Help/Content/ArubaFrameStyles/Captive_Portal/Captive_Portal_Authentic.htm
    But I’m getting error “feature is not enabled in the license
    When I try same on CLI, I get "Role 'guest-logon' is user defined, and can't be applied without Next Generation Policy Enforcement Firewall"
    Do I need to need a license to be able to configure Captive Portal ?
  • 2.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 06:37 AM
    User roles are not available when you do not have the PEF (Policy Enforcement) license.  That means you cannot create a captive portal with the manual instructions you listed above.  You can go to Configuration> WLANs and create the captive portal that way.
  • 3.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 06:53 AM
    I tried doing it like that. But still i'm getting error.
    Can you guys help as im a newbie to this.
    Find attached pic for the error
  • 4.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 06:54 AM
    That is a bug.  Which version of ArubaOS are you running?
  • 5.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 06:58 AM
    8.3.0.0
  • 6.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 07:04 AM
    Please try upgrading to 8.3.0.3 and see if you have the same issue.
  • 7.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 07:53 AM
    Just upgraded it, issue still persists.
  • 8.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 08:23 AM
    Unfortunately, the frontend is not fixed as of yet to allow WLAN creation without the PEF license.  You can either:
    (1) Obtain a temporary PEF license or
    (2) Create the WLAN on the commandline:
    You can try in CLI as below
    config t
    aaa authentication captive_protal cp_Prof)
    aaa profile cp_aaa initial-role cp_prof)
    wlan ssid-profile cp_ssid)
    wlan virtual-ap cp_vap
    aaa_profile cp_prof)
    Then you would assign the Virtual AP profile to the default ap-group:
    config t
    virtual-ap cp_vap
  • 9.  RE: feature is not enabled in the license - captive portal
    Posted Oct 03, 2018 01:37 AM
    check the error I got.
    How i can get temporary PEF license ?
    (Aruba7205) *[mynode] (config) #aaa authentication captive-portal cpProf72
    (Aruba7205) ^*[mynode] (Captive Portal Authentication Profile "cpProf72") #aaa profile cpaaa72 initial-role cpProf72
    (Aruba7205) ^*[mynode] (config) #wlan ssid-profile cpssid72
    (Aruba7205) ^*[mynode] (SSID Profile "cpssid72") #wlan virtual-ap cpvap72
    (Aruba7205) ^*[mynode] (Virtual AP profile "cpvap72") #ssid-profile cpssid72
    (Aruba7205) ^*[mynode] (Virtual AP profile "cpvap72") #aaa-profile cpProf72
    AAA Profile "cpProf72" does not exist.
  • 10.  RE: feature is not enabled in the license - captive portal
    MVP EXPERT
    Posted Oct 03, 2018 02:22 AM
    Speak to TAC who can generate a evaluation PEFNG license.
  • 11.  RE: feature is not enabled in the license - captive portal
    Posted Oct 05, 2018 01:32 AM
    Hi guys,
    Finally it worked.
    1) Enable PEF feature on Licensing Tab.
    2) Configure captive portal on WLAN
    3) Provision the AP
    4) Disable features ( if you don't disable it, OTHER  APs will stop broadcast ssid as you don't have license for PEF)
    5) Re-provision other Aps
  • 12.  RE: feature is not enabled in the license - captive portal
    Posted Oct 02, 2018 06:45 AM
    if you follow that guide, you need a PEF license per Accesspoint.
    Without this license, you can not create or edit roles.
    Captive portal can be done without these licenses, by using the built in roles (without editing them). But I recommend against this. Because I didn't bother doing this, I cannot provide a link to information, how this has to be done.
    Regards, Jörg
