Feature Request: Configurable Internal Captive Portal
  • 1.  Feature Request: Configurable Internal Captive Portal
    Posted Sep 15, 2014 03:27 AM
    As a feature request I would like to see the internal captive portal being configurable so that it is not so wide, which causes issues with small portrait devices, such as smartphones.  For these devices you could change the captive portal splash screen so it is very compact with a title, logo, conditions text and the login fields:
    Welcome to the Guest Wireless Network
    <Insert terms of use text here>
    Username:
    Password:
  • 2.  RE: Feature Request: Configurable Internal Captive Portal
    Posted Sep 15, 2014 07:20 AM
    Did you submit this to the idea portal?
  • 3.  RE: Feature Request: Configurable Internal Captive Portal
    Posted Sep 15, 2014 05:19 PM
    Thanks for the heads up.  I had added it so hopefully it will get some traction as:
    • It is practical and user experience affecting.
    • It shouldn't be that hard to implement.
    • Competitive access points already have this feature.
  • 4.  RE: Feature Request: Configurable Internal Captive Portal
    Posted Sep 15, 2014 06:59 PM
    Thank you for your valuable suggestion. Currently we have plans to solve this problem using a cloud-based captive portal solution. Once released, the cloud-based captive portal will have a variety of customization options and built-in, easy to use customization tools.
    Yan Liu
    Product Manager
    Aruba Instant
    US: +1 650 996-3520
    China: +86 136 2121 6844
  • 5.  RE: Feature Request: Configurable Internal Captive Portal
    Posted Sep 15, 2014 07:05 PM
    Thanks for the update.
    A cloud based fully featured external captive portal will be great but for small deployments, where the IAP103 hits the perfect price point, we just need a smaller internal captive portal splash screen and we have a great, cost effective solution.  The current internal captive portal splash screen is 95% of the way to what we need.  I believe that anything which adds cost to the IAP103 will adversely affect its sales in smaller markets where customers can be very cost sensitive.
  • 6.  RE: Feature Request: Configurable Internal Captive Portal
    Posted Sep 21, 2014 11:00 PM
    Is that an estimated release date for the cloud based captive portal solution?   Will it be part of Aruba Central?
  • 7.  RE: Feature Request: Configurable Internal Captive Portal
    Posted Sep 22, 2014 06:51 PM
    A customizable Guest portal via Aruba Central will be available near the end of the calendar year.  Details will be available near product launch.
