Fetching guest accounts with API not working!
  • 1.  Fetching guest accounts with API not working!
    Posted Oct 21, 2016 03:53 PM
    Hi Forum,
    I have found in this forum how to fetch guest accounts from clearpass with an API call. It looks something like what's in the link:
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-create-update-delete-ClearPass-Guest-Accounts-using-REST/ta-p/243745
    I have done all the required steps for the API and found my authorization token for Bearer and have the authorization test call returning the correct privileges for my API guest operator (this is an API client with grant type=password). here are the step I have taken to accomplish that:
    curl -X POST "https://clearpass.mydomain.com:443/api/oauth" \
    -H "Content-Type: application/json" \
    -d '{"grant_type": "password", "client_id": "apiclient", "client_secret": "DuvIvc....", "username": "testtest", "password": "aruba123"}' \
    -m 30 \
    -v \
    -k
    From that I got the authorization token and used it below to make sure I get back the correct API privileges access:
    curl -X GET "https://clearpass.mydomain.com/api/oauth/privileges" \
    -H "Accept: application/json" \
    -H "Authorization: Bearer 3f8a2d......" \
    -m 30 \
    -v \
    -k
    So I took that code for Bearer and used the info in the link above to fetch my guest list like so:
    curl  -X GET "https://clearpass.mydomain.com/api/guest/3066" \
         -H "Authorization: Bearer 3f8a2d...." \
               -m 30 \
                -v \
                -k
    This last part is not working and I wounder if ClearPass 6.6.2(mine) has something that is differant from what's in the document??
    Here is the error I get:
    >            -m 30 \
    >             -v \
    >             -k
    Note: Unnecessary use of -X or --request, GET is already inferred.
    * Trying 10.10.10.67...
    * Connected to clearpass.mydomain.com (10.10.10.67) port 443 (#0)
    * TLS 1.2 connection using TLS_RSA_WITH_AES_128_CBC_SHA
    * Server certificate: clearpass.mydomain.com
    > GET /api/guest/3066 HTTP/1.1
    > Host: clearpass.mydomain.com
    > User-Agent: curl/7.49.1
    > Accept: */*
    < HTTP/1.1 404 Not Found
    < Date: Fri, 21 Oct 2016 19:48:11 GMT
    < Server: Apache
    < Vary: X-Forwarded-For
    < X-Powered-By: PHP/5.6.25
    < Content-Length: 119
    < Content-Type: application/problem+json
    * Connection #0 to host clearpass.mydomain.com left intact
    {"type":"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html","title":"Not Found","status":404,"detail":"Not found"}Note: Unnecessary use of -X or --request, GET is already inferred.
    * Rebuilt URL to:  /
    * IDN support not present, can't parse Unicode domains
    * Could not resolve host:
    * Closing connection 1
    curl: (6) Could not resolve host:
    * Rebuilt URL to:  /
    * Closing connection 2
    * Rebuilt URL to:  -H/
    * Could not resolve host:  -H
    * Closing connection 3
    curl: (6) Could not resolve host:  -H
    * Could not resolve host: Content-Type
    * Closing connection 4
    curl: (6) Could not resolve host: Content-Type
    * Rebuilt URL to:   /
    * Closing connection 5
    * Rebuilt URL to:  /
    * Closing connection 6
    * Rebuilt URL to:  /
    * Closing connection 7
    * Rebuilt URL to:  /
    * Closing connection 8
    * Rebuilt URL to:  /
    * Closing connection 9
    * Rebuilt URL to:  /
    * Closing connection 10
    * Rebuilt URL to:  /
    * Closing connection 11
    * Rebuilt URL to:  -m/
    * Could not resolve host:  -m
    * Closing connection 12
    curl: (6) Could not resolve host:  -m
    * Rebuilt URL to: 30/
    * Trying 0.0.0.30...
    * Immediate connect fail for 0.0.0.30: No route to host
    * Closing connection 13
    curl: (7) Could not resolve host:  -m
    * Rebuilt URL to:  /
    * Closing connection 14
    * Rebuilt URL to:  /
    * Closing connection 15
    * Rebuilt URL to:  /
    * Closing connection 16
    * Rebuilt URL to:  /
    * Closing connection 17
    * Rebuilt URL to:  /
    * Closing connection 18
    * Rebuilt URL to:  /
    * Closing connection 19
    * Rebuilt URL to:  /
    * Closing connection 20
    * Rebuilt URL to:  /
    * Closing connection 21
    * Rebuilt URL to:  /
    * Closing connection 22
    * Rebuilt URL to:  /
    * Closing connection 23
    * Rebuilt URL to:  /
    * Closing connection 24
    * Rebuilt URL to:  /
    * Closing connection 25
  • 2.  RE: Fetching guest accounts with API not working!
    Posted Oct 21, 2016 04:52 PM
    Can someone confirm that the link to fetch the guest accounts should not end with 3066 like the doc mentions. It worked when I removed the 3066 but I still see the error that I noticed from before. It is fetching the guest accounts though!!!
  • 3.  RE: Fetching guest accounts with API not working!
    Posted Oct 21, 2016 04:55 PM
    The URL you were using was attempting to get guest account number 3066.
  • 4.  RE: Fetching guest accounts with API not working!
    Posted Oct 21, 2016 05:26 PM
    thanks Tim,
    what about creating an account the document has this template:
    curl -X POST "https://<ClearPass IP/hostname>/api/guest" \
         -H "Authorization: Bearer a6d2873200bee25768307c32ee22415ac8ad203a" \
         --data '{
      "enabled": true,
      "expire_time": "1438562410",
      "password": "Aruba@!23$",
      "role_id": 2,
      "username": "testaccount"
                -m 30 \
                -v \
                -k
    and mine looks like this(but it is not working with the error below):
    curl -X POST "https://clearpass.mydomain.com:443/api/guest" \
         -H "Authorization: Bearer b6d3....." \
         --data '{"email": "testapi@api.com", "enabled": true, "expire_time": "1475805555", "password": "aruba123", "username": "testapi@api.com", "role_id": 2}'\
                -m 30 \
                -v \
                -k
    error I get has this line:
    {"validation_messages":{"role_id":{"error":"Required field"}},"type":"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html","title":"Unprocessable Entity","status":422,"detail":"User and device accounts must include the role_id property"}* Rebuilt URL to:  /
    it looks like it is complaining about the role_id but as you can see I have it up there and I was able to create a guest account from the API explorer within clearpass itself.
  • 5.  RE: Fetching guest accounts with API not working!
    Posted Oct 21, 2016 05:53 PM
    Put the role ID value in quotes.
    Sent from Nine<>
  • 6.  RE: Fetching guest accounts with API not working!
    Posted Oct 21, 2016 05:56 PM
    I have tried but no luck. I just got it to work but I have no idea what I changed other than made my curl as one line instead of multiple lines. Like this:
    curl -X POST "https://clearpass.mydomain.com/api/guest" -H "Content-Type: application/json" -H "Authorization: Bearer b6d3a...." -d '{"email": "api2@api.com", "enabled": true, "expire_time": "1479165108", "password": "aruba123", "username": "api2@api.com", "role_id": 2}' -m 30 -v -k
    Tim,
    can you tell why it worked when I changed it to one line instead of multiple lines?
  • 7.  RE: Fetching guest accounts with API not working!
    Posted Oct 21, 2016 06:04 PM
    Actually never mind. what you can't see is that I have a formatting issue when I use multiples lines (I just copied the template in the document). There should no be any space before and argument for the curl. the "-H", "-m", "-v" all should have no space at the beginning. I removed and it worked.
    thanks for your input.
