Dear all,
I'm using Airwave to monitor my Wifi infrastructure (2 Aruba controller 7220), I activated SNMP/AMON on the controllers and I monitor all the devices. AMON is prefered over SNMP on Airwave.
But when I want to have more information on the authentication failure, I get few information as you can see on the picture attached. The autenthication failure are for a 802.1X SSID with a NPS Radius.
On the controller, the mgmt-server profile is configured this way:
Mgmt Config profile "amp-default"
Parameter Value
Stats Enabled
Tag Enabled
Sessions Enabled
Monitored Info Enabled
Monitored Stats Disabled
Misc Enabled
Location Enabled
Voice Info Enabled
Should I configure something more on the controller or on Airwave ?
Thanks in advance,
Thomas
