fidelio Opera controller integration
  • 1.  fidelio Opera controller integration
    Posted Feb 12, 2015 11:20 AM
    hi,
    is that possible to integrate fidelio Opera system with aruba controller without clearpass ?
    thank you
  • 2.  RE: fidelio Opera controller integration
    Posted Feb 12, 2015 11:22 AM
    You could likely make it work with custom code / web services, but nothing
    native, no.
  • 3.  RE: fidelio Opera controller integration
    Posted Feb 12, 2015 11:27 AM
    but ,
    we can do it clearpass, right?
  • 4.  RE: fidelio Opera controller integration
  • 5.  RE: fidelio Opera controller integration
    Posted Feb 12, 2015 11:37 AM
    can we do it with clearpass only, so no need for 3rd party GW,right?
  • 6.  RE: fidelio Opera controller integration
    Posted Feb 12, 2015 11:38 AM
    You will need a module on the Micros Fidelio end.
  • 7.  RE: fidelio Opera controller integration
    Posted Feb 12, 2015 12:14 PM
    what model? like nomadix?
  • 8.  RE: fidelio Opera controller integration
    Posted Feb 22, 2016 10:33 AM
    Hello Tim
    You said that in the Fidelios end need a module
    Do the client needs to buy it?
    Whats the module name??
    Cheers
    Carlos
  • 9.  RE: fidelio Opera controller integration
    Posted Feb 22, 2016 08:49 PM
    Hi Carlos,
    Yes they need to purchase the module..... here is what I have on it........ some of the below might have changed so you need to verify the cost....
    • Oracle Micros http://www.micros.com/
      • Part no: 5009-297
      • Name: Clear Pass Guest – Aruba
      • Type: WWW/IF
      • Cost is set by Micros: Approximately $3500-$4000
  • 10.  RE: fidelio Opera controller integration
    Posted Feb 23, 2016 10:33 PM
    Thanks Guys!
  • 11.  RE: fidelio Opera controller integration
    Posted Feb 12, 2015 11:43 AM
    Guys,
    Just FYI.......
    As your also likely aware Fidelio was purchased by Oracle in October of last year. We are in the process of going through an accreditation phase with Oracle. We were in progress before with Micros but have had to re-engage with Oracle post the acquisition. They have had some delays with the process associated with the merger but things are now back on track.
    NOTHING has changed regarding our integration its just than we need to re-certify/validate our solution to be apart of the Oracle PMS Eco-System.
