File Sharing using the hostname
  • 1.  File Sharing using the hostname
    Posted Feb 28, 2019 02:00 AM
    Hi All,
    I need help on this. I have a IAP-325 installed, when i connect my laptops on this AP, i am unable to share files between them using hostname though i am able to share it via IP addresses.
    this seems to be an issue just with Aruba AP, as i have couple of more APs with different vendor on which i am able to share the files using the hostname.
  • 2.  RE: File Sharing using the hostname
    Posted Feb 28, 2019 10:44 AM
    The problem could be caused by multiple issues. Questions I have or things I would check:
    • What configuration are you using on your SSID?
    • Is it connected to a bridged VLAN or are you using L3 on the IAP and acts the IAP as DHCP server?
    • Can you resolve the hostnames when you perform a nslookup or a ping to the hostnames?
