Is there a way to find an AP hostname based on (part off) the macadress in airwave or on the controller using the webbased GUI?
Kind Regards
Gerard
Hi
Yes, we can search the details if you have ip/mac address of the AP using search box. login to Airwave and top right corner you have search box.
On the right top of my airwave there is no search box, but my logout option (see attached), do you know where the search box is hidden ?
There is a magnifying glass in the upper right hand corner, however. Click it.
