Wired Intelligent Edge
Finding documentation for ArubaOS-CX switches
  • 1.  Finding documentation for ArubaOS-CX switches
    Posted May 10, 2020 03:26 AM
    Besides the documentation portfolio that can be found from ASP, where do I find the 'rest of the documentation'? For example I know there is a VSX Configuration Best Practices guide, but how does one find that by just going to Aruba web site and not just having the direct link?
    I know how to find that VSX documentation with Google but makes me wonder what else documents there are that I'm not aware of. And not just ArubaOS-CX but I'm also interested in ArubaOS-S / wireless stuff. Those new remote worker solution docs are one example. They are posted here on the forums but how would I find them by going to www.arubanetworks.com?
  • 2.  RE: Finding documentation for ArubaOS-CX switches
    Posted May 10, 2020 04:44 AM
    Did you check Aruba Support Portal https://asp.arubanetworks.com?
    You can search there for documents and filter by product series..
  • 3.  RE: Finding documentation for ArubaOS-CX switches
    Posted May 10, 2020 04:46 AM
    I did. VSX technical white paperi is there but "User Roles and User-Based Tunneling - Technical Whitepaper" for ArubaOS-CX is not.
    So I'm suspecting that there will be other documents too that are not in ASP
  • 4.  RE: Finding documentation for ArubaOS-CX switches
    MVP GURU
    Posted May 10, 2020 11:19 AM
    Hi!
    I think the majority of cited/released documents can be found carefully digging into the support.hpe.com [*] portal and the rest by digging into afp.arubanetworks.com portal (and clearly the usual asp.arubanetworks.com). What I found alarming is that more and more new editions of the most important guides/presentations/technical whitepapers started to exist (just consider how much the VSX features evolved since the AOS-CX 10.1 release...and, after two years, we are normally working with AOX-CX 10.4 devices) and thus it's becoming difficult to stay truly updated (AKA having the most fresh and up-to-date guide to study).
    Also the HPE Information Library (Networking)  helps (it's not totally updated - as example latest AOS-CX Release Notes are missing - but, at least, it's quite easy to filter/search/order by switch series, publication type/date and that really helps looking for manuals...or to just have an idea of what there is to better look for).
    [*] As example the latest  VSX Configuration Best Practices for Aruba CX 6400, 8320, 8325, 8400 for AOS-CX Version 10.4 Technical Whitepaper (Edition 1.2 March 2020) can be easily found on support.hpe.com.
  • 5.  RE: Finding documentation for ArubaOS-CX switches
    Posted May 10, 2020 11:25 AM
    I can find the VSX documentation from support.hpe.com and from ASP.
    But are you able to find that technical whitepaper describing how to use Dynamic Segmentation (UBT) with ArubaOS-CX anywhere? I haven't been able to do so. I mean not a direct link and not a forum post, but a site that would list these.
    I'm referring to document that is based on the ArubaOS-S series documentation but has some modifications to suit ArubaOS-CX.
    It is titled
    "Technical Whitepaper
    Dynamic Segmentation"
    Dated March 2020.
  • 6.  RE: Finding documentation for ArubaOS-CX switches
    MVP GURU
    Posted May 10, 2020 12:08 PM
  • 7.  RE: Finding documentation for ArubaOS-CX switches
    Posted May 10, 2020 12:23 PM
    Ah! I've been having lot's of issues with ASP as it seems that whenever I log out, I need to reset my password (I'm currently at my 12th reset). It just doesn't accept my password. For the last 10 passwords I've kept them in a notepad file to remember what is was
    I guess I tried to access AFP after my current password "expired" so that it just displayed me the login screen asking whether I am a Aruba partner or an employee. As I'm just a customer, I thought I couldn't log in.
    I created a ticket about UBT just a couple hours ago and now it seems with the new password I can access AFP.
    I found that UBT White Paper under Products, Solutions & Technology --> Campus Switching --> ArubaOS-CX --> ArubaOS-CX Technologies.
    Now I really need to dig in to AFP, as there seems to be some new documentations that I haven't heard about.
    Thanks!
