Comware
  • 1.  Finding IP Addresses of Devices connected to a switch
    Posted Jul 26, 2021 11:26 AM
    I have a few HPE 1920-48G Switch JG927A and 1920S 48G -JL382A in the network. How can i find the ip address of devices connected on each port of these switches. Going through the forums suggested me a few commands including
     show lldp info remote-device
    show cdp neighbors detail
    I am unable to see the show command on the 1920-48G Switch JG927A  model. Enabling the _cmdline-mode on command does not help either.
    Any help on this would be appreciated.
    #1920
    #1920S
  • 2.  RE: Finding IP Addresses of Devices connected to a switch
    Posted Jul 26, 2021 11:57 AM
    Hello  itisok4me,
    You may try:
    display arp
    In the command line. Note it will work if layer 3 traffic is sent to the devices like ping or the switches are default gateways for the devices.
    Hope this helps!
  • 3.  RE: Finding IP Addresses of Devices connected to a switch
    Posted Jul 27, 2021 06:06 AM
    Thank you. This works a treat on 1920 model.
    Is there a similar way to find the ip on devices connected on the 1920s.
  • 4.  RE: Finding IP Addresses of Devices connected to a switch
    Posted Jul 27, 2021 07:21 AM
    Hello @itisok4me ,
    For 1920s switch, you can refer 'LLDP Remote Device Summary' on pg.104 into below link:
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00003478en_us
    Thanks!
  • 5.  RE: Finding IP Addresses of Devices connected to a switch
    Posted Jul 27, 2021 12:45 PM
    sh arp
  • 6.  RE: Finding IP Addresses of Devices connected to a switch
    Posted Jul 26, 2021 12:04 PM
    You have to enable LLDP globally
    Network > LLDP. and Click the Global Setup tab
    You can refer pg.213 and 214 from below user guide:
    https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=c04463799
    Thanks!
