finding new controller
  • 1.  finding new controller
    Posted Aug 10, 2018 09:44 AM
    Hello Gents,
    I just came back from an event with many APs and 2 Controllers clustered. Now, I need some of the APs for a another event with different controllers. Problem is, the APs have the IP from the old controllers and therefor, can't connect to the new ones.
    Is there a autoreset if they cant reach their previous controller or can i hard reset them somehow? Cant find a reset button on the AP275.
    Just to make sure: i can ping the AP from my controller, even though they are in seperatenetworks.
    Thanks your your help,
    Raffa
  • 2.  RE: finding new controller
    MVP EXPERT
    Posted Aug 10, 2018 10:06 AM
    The below document shows you where the reset button is located and how to reset the AP.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=29188
    You should use a controller discovery mechanism in order for the AP to locate the controller.
    https://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Content/ArubaFrameStyles/AP_Config/AP_discovery_ADP.htm
