FingerPrint-AppNote
  • 1.  FingerPrint-AppNote
    Posted Jul 24, 2013 03:58 AM
    Good Morning,
    someone has experience with FingerPrint behavior?
    I have read on UserGuide that is possible create UserRole Derivation based on it, does it work correctly?
    And also, can I change the Vlan assigned to the smartphone after matching the UserRole?
    Thanks and Best Regards
    Gian
  • 2.  RE: FingerPrint-AppNote
    Posted Jul 24, 2013 06:00 AM
    Yes , are you experiencing issues ?
    It does work correctly , what AOS you have installed ? Can you shared your config ?
    Do you want to change the VLAN after the device get assign an IP from the certain VLAN on the VAP ?
  • 3.  RE: FingerPrint-AppNote
    Posted Jul 24, 2013 08:40 AM
    Yes...this works great.
    If you want to change the VLAN, you would set the VLAN id IN THE ROLE that you are applying in the user derivation policy.
  • 4.  RE: FingerPrint-AppNote
    Posted Jul 24, 2013 12:12 PM
    Thanks people for your quickly replies!
    So, in the role can I configure a different Vlan ID from the one configured in the VAP?
    Or in the VAP I have to configure both Vlan ID?
    Thanks and Best Regards,
    Gian
  • 5.  RE: FingerPrint-AppNote
    Posted Jul 24, 2013 12:14 PM
    No the VLAN ID in the VAP doesn't have to match.  In the role, you can assign a different VLAN ID.
