Firewall openings for Mobility Master
  • 1.  Firewall openings for Mobility Master
    Posted Oct 16, 2017 07:16 AM
    Hi
    I'm planning a Mobility Master setup there the MM will be in a separate network and managed devices placed on multiple subnets protected by firewalls.
    What port openings must be done for the Mobility Master?
    I have tried to find the information in user guides, startup guides etc, but so far I haven't found any consolidated information about the ports needed for a Mobility Master to work.
    Are there any document describing port needs for AOS 8.x? For 6.x I have found several.
    Regards
    Jonas Hammarbäck
  • 2.  RE: Firewall openings for Mobility Master
  • 3.  RE: Firewall openings for Mobility Master
    Posted Oct 16, 2017 07:57 AM
    Is it also the same ports between the Mobility Master and the managed device as between any managed devices?
    Regards
    Jonas
  • 4.  RE: Firewall openings for Mobility Master
    Posted Oct 16, 2017 08:09 AM
    Managed device = MD = controller managed by a Mobility Master. The link above describes those ports. The short answer is yes.
  • 5.  RE: Firewall openings for Mobility Master
    Posted Oct 16, 2017 08:47 AM
    Thank you for the clarification!
    Regards
    Jonas
