firewall settings for client isolation
  • 1.  firewall settings for client isolation
    Posted Jan 01, 2015 10:48 PM
    What are the firewall settings for client isolation that actuaqlly work?
    I've tried a mix of a few and the other clients still can see eachother.
    I'm creating a new vlan and I need the clients to be completely isolated within that vlan.
  • 2.  RE: firewall settings for client isolation
    Posted Jan 01, 2015 10:51 PM
    You can do it at the virtual AP or global level.
    Tim
  • 3.  RE: firewall settings for client isolation
    Posted Apr 27, 2017 11:02 AM
    I also having the same issue, i can not disable deny inter user bridging on 1 SSID for chromecast using airwave 8.0.x.x
    Globaly it is possible but on a specific SSID not sure how?
    can you please do a print screen.
  • 4.  RE: firewall settings for client isolation
    Posted Jan 01, 2015 11:17 PM
    You would want to use deny inter user bridging.
  • 5.  RE: firewall settings for client isolation
    Posted Jan 01, 2015 11:51 PM
    Can I use it on a single SSID or is it global?
    I only want it on ONE SSID and not the other two
  • 6.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 12:01 AM
    Yes, like I said, per virtual-ap (SSID) or globally.
    Tim
  • 7.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 12:04 AM
    How do you do that in the UI for just one SSID?
  • 8.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 02:54 AM
    Hi Friend,
    You can enable " Deny Inter User Traffic" on VAP means we are enabling this per SSID basis.
    Here is the method to enable it.
    Hope got your answer.
    Please feel free for any further query on this.
  • 9.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 03:33 AM
    Is that airwave or the hardware controller?
    Such option is not on the "instant" RAP109. My UI doesn't even look like that.
    I see an option but it's GLOBAL and I want only one SSID VLAN (5) to isolate client traffic and not ALL  SSID VLANs.
    Here's how I have it
    SSID1:VLAN10=Main unrestricted VLAN for internal
    SSID2:VLAN3=Guests and mobile devices
    SSID3:VLAN5=Client systems that need web only access for software update and antivirus definitions. <<I want THIS one to have client isolation]
    I only want the client isolation on SSID:VLAN5 and NOT the other SSID:VLANs
  • 10.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 04:11 AM
    make your rules for that ssid to be like this.
    which should achieve the client isolation for that ssid.
  • 11.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 07:03 AM
  • 12.  RE: firewall settings for client isolation
    Posted Jan 02, 2015 04:25 PM
    I used that and android clients running fing can still see windows clients
