Comware
  • 1.  *firmaware upgrade* 3com baseline switch 2924-sfp plus / JE002A HP Baseline Smart Gig SFP 24
    Posted Aug 22, 2012 09:57 AM
    Hi @ all,
    how can i upgrade the firmaware for a "3com baseline switch 2924-sfp plus /  JE002A  HP Baseline Smart Gig SFP 24"?
    I find the files and the guide, but which file must I use for the upgrade and is a TFTP server the only chance to load up the files for use?
    I find the in the guite the command like:
    ________________________________________________
    1 To download the runtime application file, enter:
    upgrade aaa.aaa.aaa.aaa rrr runtime
    where aaa.aaa.aaa.aaa is the IP address of the TFTP server and rrr is the
    source runtime filename.
    2 To download the bootcode file, enter:
    upgrade aaa.aaa.aaa.aaa bbb bootcode
    where aaa.aaa.aaa.aaa is the IP address of the TFTP server and bbb is the source bootcode filename. The bootcode firmware may not require upgrading for every software upgrade, therefore there may not be a new bootcode file to download.
    3 To set the switch to boot from the new software you have downloaded, enter the following:
    reboot
    The following prompt displays:
    Are you sure you want to reboot the system (yes, no):
    4 Enter yes and press Return. The system reboots the switch.
    I download the "MIBs-H3C-3Com_V4.0 (155MB)" from:
    https://h10145.www1.hp.com/downloads/SoftwareReleases.aspx?ProductNumber=JE002A&lang=&cc=&prodSeriesId=&SoftwareReleaseUId=3427&SerialNumber=&PurchaseDate=
    is this the right file or other one??
    And here my Versions:
    Runtime version:   01.00.07 ( date  20-Mar-2008 time  16:25:04 )
    Bootcode version:  1.0.0.14 ( date  17-May-2007 time  12:35:42 )
    Thanks in advance and best regards
    Christian
    P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to Comware based. - Hp Forum Moderator
    #3Com
    #firmawareupgrade
    #update
    #switch
    #3combaselineswitch2924-sfpplus
    #upgrade
    #HP
    #firmaware
    #JE002AHPBaselineSmartGigSFP24
    #firmwareupdate
    #firmawareupdate
  • 2.  RE: *firmaware upgrade* 3com baseline switch 2924-sfp plus / JE002A HP Baseline Smart Gig SFP 24
    Posted Dec 17, 2013 09:43 AM
    You can try to update by choosing Donwload via HTTP. You can see Source File Name, just select the file as you downloaded.
    This steps are at the same page (Restore Image).
  • 3.  RE: *firmaware upgrade* 3com baseline switch 2924-sfp plus / JE002A HP Baseline Smart Gig SFP 24
    Posted Apr 27, 2021 05:49 AM
    Works with HTTP-Upload to V1.00.10, the firmware is only 3.82 MB of size and is available in the HPE networking section:
    https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=9673&ProductNumber=JE002A
  • 4.  RE: *firmaware upgrade* 3com baseline switch 2924-sfp plus / JE002A HP Baseline Smart Gig SFP 24
    Posted Dec 07, 2023 11:20 AM
    Apologies for the necro post, however the above link no longer works, I imagine that's due to moving over to the new forum. Does anyone have an idea of where I could find updated firmware files?
