Wired Intelligent Edge
Firmware bug in 10.14 for CX 6000?
This thread has been viewed 32 times
  • 1.  Firmware bug in 10.14 for CX 6000?
    Posted 25 days ago
    While testing the latest 10.14 firmware I discovered a strange behaviour.  The switch starts normally and does its job, but the error LED flashes. A look into the log showed:
    PSU 1/1 changed state to OK
    after a few seconds/minutes
    PSU 1/1 changed state to WARNING
    Then I restarted it, but the same result.
    So I rebooted with the old 10.13.1020 firmware.
    It has been running for hours without any errors. I therefore suspect a software bug. To be on the safe side, I reported this to customer service. Have any of you seen anything like this?
  • 2.  RE: Firmware bug in 10.14 for CX 6000?
    Posted 25 days ago
    10.14 is really new; I didn't even know it was released. Reporting to TAC is indeed the best to do at this moment, as if there is an actual problem, they can pull back the release.
    It may also be that there is more thorough testing in 10.14 that now finds an issue with the power supply unit (PSU), that was not checked/tested before. TAC will probably tell you more, please update here if you have more information.
  • 3.  RE: Firmware bug in 10.14 for CX 6000?
    Posted 24 days ago
    Yes, of course, as soon as I have feedback. But so far I only have the case number.
  • 4.  RE: Firmware bug in 10.14 for CX 6000?
    Posted 22 days ago
    Some news about it.
    The support is processing the support log, because in the lab they don't have seen this problem before.
  • 5.  RE: Firmware bug in 10.14 for CX 6000?
    Posted 21 days ago
    same here with 10.14 on CX 6000 and 6100 switches
    After the downgrade everything is OK
  • 6.  RE: Firmware bug in 10.14 for CX 6000?
    Posted 21 days ago
    I have just received feedback from L2 support that it is a FW bug. Just boot the old FW and wait for the update.
  • 7.  RE: Firmware bug in 10.14 for CX 6000?
    MVP GURU
    Posted 17 days ago
    The very latest AOS-CX 10.14.0006 build  (apparently published exactly and only for 6000/6100) fixes this bug.
