Hi all
I'm trying to find the newest FAT firmware for an WA2620-AGN, but can't find it anywhere on the net.
right now the newest I managed to find is 1108
pls help
Hi There,
Are you able to send me the FAT firmware that you have to hp@support.audumla.net? I am trying to convert a fit to a fat and cannot access the firmware anyware!
Marius
Hey
Im using this version.
AP9552_AP9152_R1106P07_WW
https://h10145.www1.hp.com/Downloads/SoftwareReleases.aspx?ProductNumber=JD019A&lang=en&cc=us&prodSeriesId=4177547
That is the latest code from HP/3Com .
Did you have success with converting? Regards
