Wired Intelligent Edge
last person joined: 8 hours ago
Firmware K.16.02.0028
  • 1.  Firmware K.16.02.0028
    Posted Nov 25, 2019 02:48 AM
    I downloaded this software and copied it to my switch and after instal it said version K.16.02.0026. Tried multiply times and on to swithes, but same result. Then I downloaded K.16.02.0027 and that worked. So I think the package is wrong.
  • 2.  RE: Firmware K.16.02.0028
    Posted Nov 26, 2019 07:16 AM
    Where did you download those packages?
    I just checked on both HPE MyNetworking Portal and Aruba Support Portal, and the files that I get do contain the correct build number.
    These are the MD5 checksums that I get for the different versions:
    MD5 (K_16_02_0026.swi) = 22fa6d2f17cb8c723b84a75e6e8a0413
    MD5 (K_16_02_0027.swi) = adc2abeadb0aabbca8c9dc86e90cbf51
    MD5 (K_16_02_0028.swi) = e8980217a91c4c70d399c3c50c9539c5
    And sizes:
    15740951 bytes K_16_02_0026.swi
    15742071 bytes K_16_02_0027.swi
    15742039 bytes K_16_02_0028.swi
    Do you have the same?
    If you do a 'show version' after you installed and booted the new firmware, what is the build-date and build number? Is it actually the new firmware running or an old version?
  • 3.  RE: Firmware K.16.02.0028
    MVP GURU
    Posted Nov 26, 2019 11:52 AM
    Also...the good output of show flash command too would help to understand what happened.
    Edit: supposing you copied the new K.16.02.0028 swi file - the software image - into Secondary Flash Memory area...to then boot it (and thus install that version) was then executed the boot system flash secondary command to impose the boot from that flash area? clearly...exchange secondary with primary if you installed the new software version into Primary Flash Memory area instead.
  • 4.  RE: Firmware K.16.02.0028
    Posted Nov 27, 2019 03:05 AM
    I had 16.01.0004 in primary and 16.02.0026 in secondary, but I have never booted on the secondary. I installed the 16.02.0028 i primary and then the show flash showed that 16.02.0026 was in both primary and secondary. But anyhow, now after instaling and boot on 16.02.0027 i can now install 16.02.0028 and see it with show flash
  • 5.  RE: Firmware K.16.02.0028
    MVP GURU
    Posted Nov 27, 2019 07:49 AM
    Mate, anyway, glad you found your way.
