last person joined: 5 hours ago
Firmware Update
  • 1.  Firmware Update
    Posted Apr 11, 2014 03:10 PM
    I am looking to upgrade the firmware on my IAP cluster which consist of 56 104's and 12 135's.  I see that in the firmware upgrade section I now have two sections, one line for each AP Type.  Are there any suggestions or best practice for upgrading a multi AP environment?
    I assume I would just download the firmware for each AP type and place that in each section for the firmware upgrade?
    #AP135
  • 2.  RE: Firmware Update
    Posted Apr 11, 2014 03:18 PM
    Yes...jsut select the version for each type and upgrade.  However, I would upgrade to 4.0.0.5 and I am unsure if that is yet on the drop down list.
