Firmware update IAP-205-US
This thread has been viewed 33 times
  • 1.  Firmware update IAP-205-US
    Posted Dec 17, 2019 02:35 AM
    Good afternoon,
    Please tell me where I can download the firmware for the access point IAP-205-US
    Download from the site HP I can not, because I have not bought technical support.
    The access point I bought on ebay, I just want to update the firmware for home use of the access point.
  • 2.  RE: Firmware update IAP-205-US
    Posted Dec 17, 2019 04:32 AM
    Check Video 12 on how to upgrade the Firmware:
    https://www.arubanetworks.com/products/networking/aruba-instant/instant-training/
    You have to have WWW Access with that IAP.
    Downloading the Software needs a valid support contract.
    The way as shown in the Video does not need a support contract.
  • 3.  RE: Firmware update IAP-205-US
    Posted Dec 17, 2019 05:08 AM
    IMHO: For the Aruba Instant APs you can download the "Lifetime Warranty Software" without an existing support contract...but.... according to the 'aruba warranty and support summary':
    the warranty extends only for as long as the original end user owns the product
    Beside that, you can find the lifetime warranty software here:
    https://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/Default.aspx
  • 4.  RE: Firmware update IAP-205-US
    Posted Dec 17, 2019 05:25 AM
    Absolutly true, no doubt!
    You have to go they way over the Instant AP and start the Firmware download from there.
    All Support Portals are password protected.
    Follow this instructions:
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Basic_conf_tasks/Firmware_Image_Server_in.htm
    Section - Upgrading an IAP Using Automatic Image Check
    Therefore the IAP has to have Internet Access.
  • 5.  RE: Firmware update IAP-205-US
    Posted Dec 17, 2019 07:26 AM
    Thanks a lot, I downloaded the update from here - https://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/33556/Default.aspx automatic update at the access point for some reason does not work.
