Comware
Firmware upgrade
This thread has been viewed 45 times
  • 1.  Firmware upgrade
    Posted Feb 23, 2022 11:21 AM
    Hello everyone.
    I am new here and I have a question about upgrading comware.
    1) Is it needed to upgrade switch gradually, if I haven't upgrade switch from 2008? I am implying that in some IT system you have to upgrade first of all one version then another in order to get the latest version.
    2)  When I downloaded the new firmware from official site, it contains 3 files. The question is which firmware I should pick to upgrade and for what purpose other bin and ipe files? List of files:
    • 5510hi-cmw710-freeradius-r3507.bin
    • 5510hi-cmw710-packet-capture-r3507.bin
    • 5510HI-CMW710-R3507.ipe
    My current firmware version
    HPE Comware Software, Version 7.1.045, Release 1121
    Copyright (c) 2010-2016 Hewlett Packard Enterprise Development LP
    HPE 5510 48G PoE+ 4SFP+ HI 1-slot Switch JH148A uptime is 21 weeks, 4 days, 6 hours, 23 minutes
    Last reboot reason : Cold reboot
    Boot image: flash:/5510hi-cmw710-boot-r1121.bin
    Boot image version: 7.1.045, Release 1121
    Compiled Aug 17 2016 16:00:00
    System image: flash:/5510hi-cmw710-system-r1121.bin
    System image version: 7.1.045, Release 1121
    Slot 1:
    Uptime is 21 weeks,4 days,6 hours,23 minutes
    HPE 5510 48G PoE+ 4SFP+ HI 1-slot Switch JH148A with 2 Processors
    BOARD TYPE: 5510 48G PoE+ 4SFP+ HI 1-slot Switch
    DRAM: 1984M bytes
    FLASH: 512M bytes
    PCB 1 Version: VER.B
    Bootrom Version: 123
    CPLD 1 Version: 003
    Release Version: HPE 5510 48G PoE+ 4SFP+ HI 1-slot Switch JH148A-1121
    Patch Version : None
    Reboot Cause : ColdReboot
    [SubSlot 0] 48GE+4SFP Plus
    Askar Daldabay
  • 2.  RE: Firmware upgrade
    Posted Feb 24, 2022 02:31 AM
    Hi Askar.
    You need .IPE file for the upgrade. Please consult release notes on required upgrade path from your version. https://support.hpe.com/hpesc/public/docDisplay?docId=a00120477en_us
    On first look you can upgrade directly to 7.10 R.35.07.P03 but check anyhow. Also there are tons of changes between these two releases so check them also.
    Best, Gorazd
    Gorazd Kikelj
  • 3.  RE: Firmware upgrade
    Posted Feb 24, 2022 03:44 AM
    Hello Askar,
    In addition to what Gorazd said I would like to add the following files are patches for freeradius and packet captures which are providing functionality patches to the main firmware which is .ipe.
    Hope this helps!
    -Alex-
  • 4.  RE: Firmware upgrade
    Posted Feb 24, 2022 03:52 AM
    Thank you Gorzad and Alex, that simplifies a lot.
    Askar Daldabay
