Comware
Firmware/Software Download/Upgrade & Release Notes for HPE Networking Products
  • 1.  Firmware/Software Download/Upgrade & Release Notes for HPE Networking Products
    Posted Sep 06, 2018 03:54 AM
    Follow the below steps to search and download/upgrade firmware/software:
    1. Login to the My Networking Portal. Click here.
    2. In the Enter Search Information field, type the product number or name. [Do not type the serial number]
    3. Select the appropriate model by ticking the check box. Select multiple products by ticking multiple check boxes.
    4. Under the Product information/Warranty support click on Software downloads and a list of software versions available will be displayed.
    5. Choose the latest or appropriate firmware/software bundle and click on the arrow button under Select column.
    6. Click on the Download button to save the firmware/software bundle.
    Release Notes:
    View the procedure to perform software/firmware update, by clicking on the Release notes under Notes column.
    In the Release notes file, refer to the Upgrading Software section for the instructions to update via FTP, TFTP, Xmodem or CLI using the Ethernet, console port, etc.
    NOTE: To know the Previous product information and Current HPE product information click on the Conversion information tab.
    #firmware
    #Modems
    #upgrade
    #Software
    #switches
    #ReleaseNotes
    #wireless
    #Hubs
    #Networking
    #download
