First CPPM Server Error joining Domain
  • 1.  First CPPM Server Error joining Domain
    Posted Jan 28, 2015 10:27 AM
    I have stood-up our first CPPM VM server and it is up and running, on the network, and pulled down all updates and patches.
    When I attempt to add it to my domain, I receive the following error:
    Failed to join domain: failed to lookup DC info for domain
    'ROCKWALL.GENESTA.COM' over rpc: NT_STATUS_CONNECTION_RESET
    INFO - Restoring smb configuration
    INFO - Restoring krb5 configuration file
    INFO - Deleting domain directories for 'ROCKWALL'
    ERROR - CP01 failed to join the domain ROCKWALL.GENESTA.COM with
    domain controller as dc02.rockwall.genesta.com
    Join domain failed
    The DNS server is correctly configured and I am using either my account, which is an Enterprise Admin account or the domain administrator account.
    I cannot find any info on this error and I am at a lost at this point. Please Help!
  • 2.  RE: First CPPM Server Error joining Domain
    Posted Jan 28, 2015 11:18 AM
    Are the appropriate firewall ports open between ClearPass and your domain controllers?
    Also try using your FQUN instead of just the username.
    Tim
  • 3.  RE: First CPPM Server Error joining Domain
    Posted Jan 28, 2015 11:19 AM
    My ClearPass resides on the same subnet as my DC, so firewalls are not an issue there.
    I am using my username@domain as I read in the instructions.
  • 4.  RE: First CPPM Server Error joining Domain
    Posted Jan 28, 2015 11:21 AM
    Can you try pointing it at a different domain controller?
  • 5.  RE: First CPPM Server Error joining Domain
    Posted Jan 28, 2015 11:28 AM
    I would have to stand another one up on my network as that is my only Domain Controller at this point.
    Do you have any ideas what that error is?
  • 6.  RE: First CPPM Server Error joining Domain
    Posted Jan 28, 2015 11:31 AM
    Is the time set correctly? You might want to set NTP to use the domain controller.
  • 7.  RE: First CPPM Server Error joining Domain
  • 8.  RE: First CPPM Server Error joining Domain
    Posted Jan 29, 2015 03:43 AM
    May this help you to solve your problem..
  • 9.  RE: First CPPM Server Error joining Domain
    Posted Apr 12, 2018 08:59 AM
    Hello!
    Have you find a solution for the problem?  I have this problem too.  We trying to change our AD server.  Then I leave the old one and I'm not able to join the new server.
    THanks
  • 10.  RE: First CPPM Server Error joining Domain
    Posted Apr 12, 2018 10:15 AM
    What error are you getting ?
