First Project: Serious Packet Loss Issues
  • 1.  First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 04:32 PM
    Hey All,
      I am experimenting with the Aruba Instant Product Line in my own home and have purchased 4 IAP-105's as a result.  I am currently using 2 of them and having some pretty odd issues that I did not have with the lower-end Meraki piece when testing.  Basically I am seeing HUGE packet loss of about 15-20 %.
      It seems like the packet loss only occurs on one of the AP's but I haven't tested extensively enough at this point.  The wired network is near-perfect with little-to-no packet loss.
      It seems that the problem most occurs when trying to access bandwidth on any serious level.  When streaming videos the network will rarely be able to watch anything (even the lowest quality connections).  This is with any kind of device from 5 Ghz to 2.4 Ghz.  When I look at my uplink Transmit Rate it is generally 300 Mbps or in the mid-200's.
      However, when I look at my speed graph is when the problem becomes apparent.  Here is my graph while working with bandwidth-intensive work including FTP & Video Testing for a new company intranet. (See Attachment: ArubaSpeedMacbook.png)
      This same graph can be created on any device by simply browsing or using the WiFi at all.  For example, if I were to pick up my Android phone and try to go to a website, the following will happen.  Both of these are via 5 Ghz.  (See Attachment ArubaSpeedAndroid.png)
      As a test I created a 2.4 Ghz Network and began running speed tests in order to simulate bandwidth usage.  The same thing happened.
      Out of the 4 there is another that is having something somewhat similar where every time I connect to the Access Point it will restart itself as soon as any kind of bandwidth is used (Speedtest.net will restart the AP every time).  Support asked me to send that in for repair.  This is kind of similar because it happens whenever.
      Hoping that there is a simple explanation for this type of behavior!  I have a support contract but I am awaiting their callback and it's been awhile - trying to get work done here! :-P
      Thanks for any support or help you guys can offer on this issue!
  • 2.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 04:36 PM
    Good night :)
    • Are u using the lastest version on the InstantOS? 6.2.0.0-3.2.0.2_37229
    • Are you using 40Mhz in 2.4Ghz? if so - disable it and use HT and 20MHZ in 2.4GHz.
    • Are there any other AP unit on the same location that running? (that arent aurba?)
    • Try to disable all the WIP/IDS - and test the results?
    • Are the videos your trying to trsnamit using multicast?
    waiting for an update in order to keep helping you to solve your issue.
    me
  • 3.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 04:42 PM
    Yes
    No, 20 Mhz Only in 2.4 Ghz.  I don't know what "HT" is though.
    No, I have two IAP 105's and that is it at the moment.
    I never set any.
    No but I have a control system in the project that multicasts information to wifi devices.  It is not a lot of communication - just text updates for song meta data and updates as-to what is happening in various rooms.  A total of 9 devices on the network total.
  • 4.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 04:50 PM
    I also take back the fact the problem is only occuring with a single AP.  The results of the virtual controller are WAY WORSE.  I am sitting around 5 feet from the AP at the moment.
  • 5.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 04:58 PM
    HT= 802.11N
    regarding the screenshots u sent..5 fett from the AP - if thoese are the results - you got some radio issue. (that what i can understand from your post and your screenshots)
    please copy&paste your config.
  • 6.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 05:04 PM
    version 6.2.0.0-3.2.0
    virtual-controller-country US
    virtual-controller-key 28806322014a4e072dbebfb5b52b33a6b0a0565b0438df8bdd
    name "Brady Net"
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 6c:f3:7f:c9:cd:f2
    allowed-ap 6c:f3:7f:c9:cc:0e
    allowed-ap 6c:f3:7f:c9:cd:f6
    arm
    wide-bands 5ghz
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode default-access
    client-aware
    scanning
    rf dot11g-radio-profile
    interference-immunity 1
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin 5a95df500a00b9d84950dbbdc2f42892
    wlan access-rule default_wired_port_profile
    rule any any match any any any permit
    wlan access-rule Edman
    wlan access-rule Napier
    wlan access-rule default_dev_rule
    wlan access-rule JoshsShittyWiFi
    wlan ssid-profile Edman
    index 0
    type employee
    essid Edman
    wpa-passphrase 7c2f6d597c8ad356c1adcd9c38f0059a35c31bcfea2a1f70
    opmode wpa2-psk-aes
    max-authentication-failures 0
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    g-min-tx-rate 5
    blacklist
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile Napier
    index 1
    type employee
    essid Napier
    wpa-passphrase db8cffd0cd9707004263b8f5e631a61965d5b805a238a239
    opmode wpa2-psk-aes
    rf-band all
    dtim-period 1
    a-min-tx-rate 12
    wlan ssid-profile JoshsShittyWiFi
    index 2
    type employee
    essid JoshsShittyWiFi
    wpa-passphrase 236bbf2b13627588a73d55f01e1b4df1a060f7ffbff38226
    opmode wpa2-psk-aes
    rf-band 2.4
    dtim-period 1
    broadcast-filter all
    multicast-rate-optimization
    dynamic-multicast-optimization
    enet-vlan guest
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    id _airplay._tcp
    id _raop._tcp
    airgroupservice airprint
    disable
    description AirPrint
    id _ipp._tcp
    id _pdl-datastream._tcp
    id _printer._tcp
    id _scanner._tcp
    id _universal._sub._ipp._tcp
    id _printer._sub._http._tcp
    id _http._tcp
    id _http-alt._tcp
    id _ipp-tls._tcp
    id _fax-ipp._tcp
    id _riousbprint._tcp
    id _cups._sub._ipp._tcp
    id _cups._sub._fax-ipp._tcp
    id _ica-networking._tcp
    id _ptp._tcp
    id _canon-bjnp1._tcp
  • 7.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 05:06 PM
    Airtime fairness was changed to default after this problem started, by the way just as a test to see if that was the cause.
  • 8.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 05:13 PM
    In order to make a clean test please:
    • Clean all the ssid
    • build just 1 ssid - with no encryption from any kind
    • be sure - to set in the ARM band sterring not to prefer 5Ghz(during the test)
    • in the ARM profile - interference-immunity 1 < change it to 2 please.
    update me in the result.
  • 9.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 05:31 PM
    No change.
  • 10.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 05:33 PM
    You wrote in your first post - that your speed issues are in 5GHZ.(you worked in 5GHZ and picture the 2 screenshots)
    then i asked for u to make an 2.4GHZ only network - and again - you suffer from low bandwidth/speed.
    Am i right? :smileysurprised:
    • So - Let's see if someone else here might have any idea. (did u open a case in front of Aruba TAC?)
    • Did u tested those AP units in another environment and location? To be sure.It aint location radio / interference issue.
     Have a lovley night.
    me
  • 11.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 06:09 PM
    I tried to open a case but they claimed I didn't buy support (which I did and have used it in the past for this AP) then they said they would call me back 3 hours ago... no reply.
    What I find weird is the amount of retries I tend to see - is this normal?
  • 12.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 04, 2013 07:01 PM
    The problem may have been resolved by re-provisioning all the IAP-105's but I also noticed that it is assigning all my SSID's to the same channel (6) even though ARM is on.  Is this normal?
  • 13.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 05, 2013 11:06 PM
    There is nothing that says all of your access points will stay on the same channel.  In addition, there might be interference or other access points on the other channels.  Use inssider to look at and see.
  • 14.  RE: First Project: Serious Packet Loss Issues
    Posted Mar 05, 2013 12:29 PM
    The amount if retires aint normal.
    Putting the all the SSID from the same unit on the same channel - yep,it's normal.
    Regarding your poor performance - try to check if it's environment related,and take one of your virtual controllers and installed them standalone (only with 1 ssid - no encryption) and test it.
    Me
