First step configuration of AP225 after reseting the AP
  • 1.  First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 10:28 AM
    Hi Guys,
    My Colleague has forgotten the password of new AP and I had to reset the AP. I went through CLI( Via console cable connceted) and made factory reset and set new ip address, mask and getway, saved all this and rebooted. But I couldn't ping or browse it's ip address. Then I added also master controller IP address.
    But without any luck. i can't conncet to the device.
    Please help me, that I didn't do right?
  • 2.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 10:51 AM
    Make sure its taken the IP.
    You can check the same using #show ip interface brief
  • 3.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 10:56 AM
    what do you mean by taken IP?
  • 4.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 10:58 AM
    Means you configured the IP properly and its taken that.
    #sorry #badenglish #tryinghard
  • 5.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 11:05 AM
    No it doesn't gives any such output. Si i think i made everything ok. But why it doesn't work? should i do some enable commnad? or maybe i missed something?
  • 6.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 11:06 AM
    Let me confirm its AP or IAP ?
  • 7.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 11:10 AM
    That's AP
  • 8.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 11:18 AM
    You can check the followings.
    1. Break boot option and issue #printenv and check the parameters.
    2. Make sure from your vlan or from your master controller vlan the IP of AP is routeble.
    3. try to ping the controller from AP.
  • 9.  RE: First step configuration of AP225 after reseting the AP
    Posted Jul 07, 2015 03:20 AM
    Thanks to all. I was be able to solve the problem myself. Thanks for your support!
  • 10.  RE: First step configuration of AP225 after reseting the AP
    Posted Aug 06, 2015 08:41 AM
    Tiko, what did you do to resolve the issue?
  • 11.  RE: First step configuration of AP225 after reseting the AP
    Posted Jun 29, 2015 11:15 AM
    HI Friend,
    Clarify couple things here,
    1. How many Controllers you have in the setup ?
    2. do have external DHCP or you are using COntroller as the DHCP ?
    3. On apboot mode, are you able to ping the Controller after applying the IP address and gateway ?
    Please clarify the above , we can fix the issue very easily.
