last person joined: 11 hours ago
Flapping SSID / AP's
  • 1.  Flapping SSID / AP's
    Posted Apr 07, 2016 08:23 AM
    We've got two IAP-325 configured with 1 Virtual controller. Both AP's can see each other and they are both accessible in the VC. But it seems like the configuration is flapping between the two AP's. I've added an attachment where i marked 1 SSID and it constantly switches/flapping between the AP's. This is on 2.4 Ghz and 5 Ghz.
    We only have this problem with the IAP-325 not on other models.
    We use firmware: 6.4.4.3-4.2.2.1_53878
    Does someone know an solution for us?
    Tom ter Huurne
  • 2.  RE: Flapping SSID / AP's
    Posted Apr 07, 2016 08:46 AM
    What are you using to measure that?  did you try a packet capture, filtering by bssid instead?
